Corel Draw X7 Entension not working w/ Sure Cuts A Lot 3 Pro
I have Cored Draw X7 and I downloaded the extension to send to Sure Cuts A Lot 3 Pro. This route is not working nor is the SVG save option. Does anyone have any advice? I have something I need to cut by tuesday and this is getting rather frustrating.
Re: Corel Draw X7 Entension not working w/ Sure Cuts A Lot 3
The Corel extension for Sure Cuts A Lot 3 Pro will only work up to Corel Draw X6.
For X7, you need to use Sure Cuts a Lot 4 Pro.
Alternatively, you can export from Corel Draw X6 as a SVG and import that SVG into Sure Cuts A Lot 3 Pro.
If you are exporting text in the SVG, make sure you set the option to export text as Curves when you export as SVG in Corel Draw
- Craft Edge
http://www.craftedge.com
