Image prints with "White Rectangles" in a repeating pattern
kemo56
Post by kemo56 »
:?: http://prntscr.com/940b7p it will print fine in grey scale. I am printing from Sure Cuts A Lot 3 Pro using the cut/print with registration marks to a HP DesignJet 111 Roll printer ... the file is a little less than 23"x21"... Thank you for your time and consideration in this matter, any ideas would be appreciated.
Kemo
Re: Image prints with "White Rectangles" in a repeating patt
Kemo, attach the real scal file here and I'll take a look at it and see if I can figure it out.
kemo56
Post by kemo56 »
Hello, Thank you for answering my post ... the file will not up load as it is too big ... max seems to be 2MB and this file is 5.4MB ... I am attaching 2 rows of the file, which I duplicated to 5 rows making 140 stickers ... the black ovals I have for contour cutting so the sticker will have no white ... the squares marking the corners are there because it was my plan to print 144 rows at once (2016 stickers), then I would manual put in the registration marks so I would cut 140 stickers at a time (so I would not lose accuracy in the cuts) ... but that didn't work so I was trying to only print the 140 and print copies, which still doesn't work ... There must be an easier way ... I make these stickers only once a year 2000 at a time, but still ...
Thank you for any ideas you might have. Don
2rowslogos.scut3
(1.07 MiB) Downloaded 198 times
Don, it appears to me that you have some extra layers in the file probably caused when you duplicate. Try turning some on/off and see which ones. Then check view outline only as there appears to be some cut lines missing too.
Let us know if this was helpful and that you are back to packaging your [Incredible Candies[/b]!
