not sure if sca is installed or not ?
i purchased the full version a while back before they had fixed the xp issues anyway i got a email telling me that all was sorted and to download the new version which i did and to be truthfull i have not had the time to look at it untill this morning when i start it up i get this screen please see attached there is no font libary all i get is what is on the screen shot
- sca.jpg (85.46 KiB) Viewed 2639 times
Re: not sure if sca is installed or not ?
CHRISTINE. The little screen with all the squares is the keyboard screen with the fonts. Make it big and scroll to the bottom.. your chosen font is there. The column has your fonts to choose by clicking on the one you want. I hope this helps because when I first used SCAL it was confusing to me...
Sorry.. you can make that keyboard screen larger by stretching it ( put your mouse arrow on the edge of the screen and drag it to expand it..You also should by able to type in your letters using your keyboard...
Your font library must be behind the other screen. When you first clicked to open your SCAL did it tell you what version you are running on.. You will want to update by downloading to 1.006.
hi
know there is no other screen running behind anything and it tells me i running 1.006 version
It has to be installed. Dd you close out and try to open it again to see if that helps.? Maybe some one else knows that had a problem like this.. I know if you email Todd at Craftedge that he will help you as soon as possible. I know a lot of people are sleeping at this time... I am a early riser..
In another post, someone said to do this: In the Preferences, try clicking the Restore Defaults button, and the
windows should re-appear. To get to Preferences, click on Edit, then Preferences.
wreed06 wrote:In another post, someone said to do this: In the Preferences, try clicking the Restore Defaults button, and the
