need some help
need some help
I need some help... I found this shape online and opened it as a .bmp in inkscape and traced it... well now if I were to cut it in SCAL it would cut as a thin outline... Can anyone help me fix that? My ultimate goal is to put a date in the middle of it... i enclosed a picture of what i would hope it looks like...
- example.jpg (32.98 KiB) Viewed 2117 times
- bracket.svg
- (4.49 KiB) Downloaded 108 times
Jodi
Re: need some help
Ive d/l the file I see you have that extra line around the frame try this blog to remove the line to start with.
http://susanbluerobot.blogspot.com/2008 ... ouble.html Hope thats a help.
Re: need some help
I will give it a try! Thanks for the help... I will let ya know what I find...
Jodi
Re: need some help
looks like it might work now!!!
I had a slight problem when I "broke it apart" the layers were all the same color... once I figured that out I was good to go..
thank you again for pointing out that tutorial...
Jodi
Re: need some help
I just made this name plate yesterday. Hope you can use it. Rebecca
- nameplate1.scut
- nameplate1.scut file
- (3.13 KiB) Downloaded 137 times
