Need Templates?? This website has EVERYTHING
jsnstarprncss
Post by jsnstarprncss »
My grandma does a lot of stuff on the computer using Print Shop and Hug Club, but she also uses this website to get templates. I believe you can import them to Inkscape. Enjoy :)
http://www.jersgirl.com/temps.html
~Ashley
Psalm 113:3 Creations
Tingha Treasures
Re: Need Templates?? This website has EVERYTHING
Post by Tingha Treasures »
They are excellent but a little hard to get rid of the score marks so SCAL doesnt show them as cut lines.
Anyone got an easy way of getting round that? :D
jsnstarprncss
I just imported something into inkscape and when you break it apart you can delete what you don't need. You can also delete nodes if they seem still connected. HTH :)
~Ashley
Tingha Treasures
tried that with the teabag one it just mucked up......
sometimes its the way theyve connected the nodes.
I did take it into PSP and rubbed out the score lines then took it into Inkscape that worked :D
jsnstarprncss
Question: How are you saving and importing? and are you using Inkscape.
I downloaded the image as bitmap, imported it into Inkscape, then did outline view and traced the bitmap at .99 edge detection. Then broke everything up, deleted everything inside the outline. It took me like 2 minutes tops. I attached the SVG (teabag) file.
Is this what you did?? I just want to see if I'm doing something different then what everyone else is.
THANKS!!
teabag.svg
teabag holder
(3.37 KiB) Downloaded 142 times
~Ashley
Tingha Treasures
thanks for that, yep looks like your on the right track!!! With Inkscape and SCAL the cuttings unlimited :D
