I have several embroider allpique files that I want to make into files to use on the cutter?
HELP
HELP!!!How DO I turn my applique files into cutter files?
Re: HELP!!!How DO I turn my applique files into cutter files
Kelli, depending on the design you could import the jpg/png picture of the image and try to trace it either in SCAL or Inkscape. You will most probably have a LOT of nodes so be sure and do a path/simplify before you try to cut it.
If you find one you LOVE and can post a link to it someone will help you convert it.
Good Luck
Good Luck
It seems like the files for the embroidery would be vector files as well. You could see if they will open in Illustrator, and then just save them as svg files. Good luck. I'll be interested to see how this works out.
