layering letters
anniekay67
layering letters
Post by anniekay67 »
I can't figure it out. I need:
NO MERCY
RACING
TEAM
About 12" high, with smaller letters inside it. I can't figure out how to do it. I know it has to do with welding. Any suggestions
Re: layering letters
Hi, a couple of questions. Do you design in SCAL or Inkscape.
I don't understand what you mean by smaller letters inside, can you elaborate a bit?
anniekay67
I am using scale. I need to have two layers. One on top of the other. With the top one being smaller so you can see the bottom layer. I think I need to weld the bottom letters then I am lost
One more question and then I think I'm ready to do a cheat sheet like a did the other post.
Do you want all three words with their own bottom layer or one bottom layer with the 3 words on top?
anniekay67
One bottom layer. then lay other letters on top of welded bottom
See if this is what you want.
This cuts in two pieces. All the bottom and then the top.
Screen Shot 2013-04-19 at 7.05.58 AM.png (51.19 KiB) Viewed 5105 times
anniekay67
Looks awesome. But now husband wants it in two lines. NO MERCY then below it RACING TEAM
OK, here is a scut2 file that I did. I made notes in the NOTES in WINDOW/PROJECT NOTES with the steps to do it.
There will only be two layers to cut separately and adhere together. I sure hope that I have remembered SCAL2 enough for this to work for you.
Pick your font and size and get started. You can do this!
I'm not going to be unavailable for 2 weeks, starting tomorrow, so if you have any more questions you'll need to post again or get back to me tonight. I'm in CA so it is a little earlier here.
Instructions for DIY
  • Type your text on two seprate lines
    Move the Racing team up to just cover the bottom edge of No Mercy.
    Select ALL Path/Union. This makes on object of the two lines and will cut as one piece.
    Select the image and Copy/Paste in Place. Now the copy is ontop exactly above the original and it should be still selected.
    Go to the Appearance Panel on the right hand side of the Mat screen
    Style with show as NORMAL. Change to Shadow/blackout Rounded. You can adjust the size of the shadow to fit your wants.
    Now the shadow layer is on top of the image. Object/Arrage/Send to back should do the trick of lowering the mat below the text. Or you can just drag them apart if you are going to cut them separately.
BTW I did you a tut last week for making the image for your Aprons but didn't hear a thing from you. Did that work out?
Good luck.
Layer Text.scut2
(190.56 KiB) Downloaded 211 times
mitsim
Post by mitsim »
Papasue, I know this doesn't have anything to do with anything, but you mentioned you are from CA, and so am I. Was just wondering if we were anywhere near each other. I'm in San Diego area.
Luv San Diego..but rooting for the Giants tonight, I live in San Jose..50 miles S of San Francisco.
It would be good to have someone near to play with tho.
