Unable to open .svg created in Inkscape
Scramper
Post by Scramper »
I have some clipart I traced in Inkscape and saved as a SVG file. However, when I try to open the file in SCAL 2.0, it keeps giving me an error message saying "Failed To Open The SVG File" I then tried copying the Inkscape file into a new file, with a new name and it still isn't working. Anyone have this problem before that can offer a solution please?
Re: Unable to open .svg created in Inkscape
Are you Opening or Importing the file? SVG files must be Imported. Also, if you could you attach one of the files so that we could see what you are trying to import?
dragonlord666
Post by dragonlord666 »
have you been able to open inkscape svg's before?
check it's saving as inkscape svg not one of the others
Gaz
Computer:IMac running Mojave
mitsim
Post by mitsim »
What Heather said. Remember that you "open" scut files and "import" svg files.
luvs2scrap
Post by luvs2scrap »
I have the same problem, Error: Unable to load file. It is my first time creating a svg file from Inkscape, followed the scrappydew tutorial on youtube. Used the +SVG tab in SCAL2. Tried to embed and link (neither worked), tried saving as an Inkscape svg and a plain svg (neither worked), tried different combinations of those 4 options, nothing worked. Any suggestions would be greatly appreciated.
Can either of you attach the file you are having problems with that do not violate someone's copyright. It would make it easier to help you if we could see the files.
Which video? Did you trace an image? Link and embed are choices for images, not vectors. I do use embed for print 2 cut files and eCAL/SCAL3, but you still need a vector to trace.
Also, did you know that there is an Inkscape extension (also one for AI) so that you can send your file directly from Inkscape to SCAL3/eCAL without needing to save or import the file? I use it all of the time since it saves a step or two. :D
http://www.craftedge.com/download/download_extras.html
luvs2scrap
Thank you for your quick responses and offers to help! The youtube video is called, "Sure Cuts A Lot: Color Tracing an image using Inkscape to use in SCAL" by scrappydew. I use the SCAL2 for cricut so I cannot update it. I also have Mountain Lion on my mac so I am using the latest Inkscape. When I import my jpg, Inkscape automatically asks if I want to embed or link, there are no other choices. So I trace bitmap using the multiple color option (6 scans) then I ungroup everything and save each color to it's own svg file. I have also tried moving all the colors apart and saving them all together in the same file, no luck there either. If you can provide some hint at what I am doing wrong I would greatly appreciate it!!
Princess pink 1.svg
(140.11 KiB) Downloaded 803 times
Your file doesn't have a vector in it, it is just the image. If I remember correctly, this has come up before with a Mac. I believe you need to install something. I'll take a look and see if I can find it (unless a Mac user posts first).
Is your original image one color or multi-color? If it is one color you should use Brightness Cutoff rather than Color. Multi color traces are often a bad idea since it stacks the colors dark to light with every color underneath the dark.
luvs2scrap
The original is multi color. I did install the X11 to support Inkscape and everything seems to be working fine. If there is anything else I need I would be happy to know it!!!
