If you do this the normal Path>Object to path command will not work as non closed paths ( ie straight lines) do not obey the same rules as closed paths ( squares, circles etc) so the command to use when you have single non connected lines on your template is
Path>stroke to path then save as .svg.
Try and see!
Susibi
