: add your own customised page size
Default for Inkscape is portrait.
If you prefer to work in landscape mode this is how you set it up as default: Open Inkscape> new page ( click on the little arrow to the right of New) A4 landscape or letter landscape >File>save as
and call your file default.svg
now browse to
My computer>C:>programs>Inkscape>share>templates and click on Save- in the warning screen that pops up telling you that default already exists and asking if you wish to overwrite click on yes.
Now close Inkscape then reopen when you click on File>new your page should come up in landscape format.
In the top tool bar remember to specify the units you wish to work in ( points, pixels inches mm etc).
As SCAL is in inches the best thing to do if you work in metric is to make your template in Inkscape then before saving as .svg click on the units box on the tool bar and change the units to inches - this will show you what size to resize to in SCAL. ( I came up with this idea after a lot of head bashing doing metric to imperial in SCAL).
SCAL gives you the possibility of choosing your mat size ( Cutter>mat size ) so this is how you can add those measurements to the list of page sizes available in Inkscape:
Example of adding a 12x12 page size:
Open Inkscape > File > new page
File > document properties scroll down to the measurements box.
Change the units box to inches
insert width 12 height 12 . You will see that your page size changes.
Now File>save as 12x12.svg browse to find the folder where you'll save this file -
C.>programs>Inkscape>share>templates click on save
Close Inkscape
Open and you'll see that when you go to File>New 12 x 12 has been added to the list of templates available.
If you want 12x12 to be your default page follow the instructions above.
I used inches as SCAL is in inches and until that changes the less translating we have to do the better.
This way you can make and add any number of templates to your template menu.
Susibi
