Hi, do you have a Gazelle and use SCAL with it? I am wondering if you have any of the issues I'm having with it. I have the full SCAL version three and I have been trying to cut one doily on walmart cardstock for an hour and a half. Out of twelve non cuts, I have one that cut all the way through. I've wasted so much paper. It will cut some and then veer off and cut a straight line away from everything and when I click cancel the whole machine locks up and I have to turn off and start all over and to repeat all this again. I have no idea what I am doing wrong.
If you have had any of these issues, can you please tell me how to fix them?
Thanks for any help.
Bosskut Gazelle and SCAL
Re: Bosskut Gazelle and SCAL
are you cutting to large meaning is it a large design. I have the gazelle but haven't used it much in the last few months and I have scal 3 if you would like me to try and cut the same file let me know and I would be happy to help.
Hi...I don't think the file is to big. Maybe it's to intricate, I don't know.
I hope the file attached on here and thank you so much for doing this for me. I am sure it will work great for you.
This machine and I don't get along, my Cricut and I didn't get along either. I don't know what I do wrong.
- Lattice_13.scut
- (224.52 KiB) Downloaded 163 times
How come when I click the cancel button it shuts off the red button on my Gazelle and I'm not able to get my paper out unless I turn it off and start again.
I'm quite sad and tired over here with this machine. Can anyone help me understand this, please.
If u still have Funtime installed start cutting something, cancel it and see if the same thing happens. If I doesn't then you will know it's a problem with the communication between SCAL3 and the machine. Might be a bug in SCAL3 cuz the Cricut didn't have a Cancel button on the machine on only the software.
As far as getting the paper out, did u try pulling the mat out. U may be able to pull it out like u do when doing an alignment and u have to manually roll the mat.
HTH
Althea
HTH
Althea
