Ok so I'm trying to use the "place image" print it, bring the printed graphic to my cutter (a cricut expression) then cut the outline of the svg.It's not working, I'm almost cutting the image but I just can't get it right. In the older version wasn't there a place you could calibrate your printer to SCal? I can't find it.
I don't have adobe photo shop. I do have windows 7, Scal version 2.41, and inkscape. Any ideas? I tried a version on you tube but no matter what I do I can't get it right.
Thanks!
I'm trying to use the Print & Cut HELP
Re: I'm trying to use the Print & Cut HELP
IN Scal look under Cutter and then calibrate..
Yes but what does calibrate do? I can't find anything on it. The only reliable method is the hinge technique. Is print & cut on SCAL3?
