Lines Breaking Apart?
heathrjoy
Post by heathrjoy »
Ok, this seems so simple...but, why is it doing this?
I'm having a problem with my lines getting breaks in them once I open my SVG file in SCAL. The breaks are right along the bounding box (the dashed line box that shows up when you have selected your image in INK). I haven't actually cut anything yet...I haven't wanted to waste anything. I'm assuming that since it's not showing a line it won't cut. The really weird thing is that sometimes when I resize the image in SCAL the breaks disappear and reappear. What's going on? Am I doing something wrong, or is this just something that happens randomly sometimes and is nothing to worry about (will cut fine anyway)?
Here's exactly what I did...In Inkscape
Opened a new file
opened a new text box (or whatever it's called)
selected text settings from the drop down
set my text settings to Pegasus and to 144 size, selected apply and then closed
I typed what I wanted my text to say (Ho and pe...separate files, both gave me the same problems)
clicked off the text so that then I could select it, then selected it
Then did the trace bitmap (even tried skipping this step once and it made no difference whether I did it or not)
Then did the object to path
Then saved as an SVG
When I opened these SVGs in SCAL I was resizing them to super size. They were pretty small when I opened them and I need to resize them to be around 6" tall letters. That's why two files..."Ho" and "pe" to spell out "Hope"...it won't fit across the mat as one word. Is it because I am resizing them to be so large?
The other thing I've noticed is when I'm working with INK that every now and then I'll get random lines streaking across my images. This is whether I'm working with text, dings, or jpegs. When I select and move the image around my screen the random lines move all over the place and sometimes I can get them to disappear. These lines don't show up on SCAL, but often it's where I will have a cut line missing.
I am running Vista (down with Vista :oops: !) I have compatibility set for XP Service Pack 2 and running as Admin....if that may be causing any problems...those are my settings for INK. I don't have any compatibility settings on for SCAL, do I need to?
Anyone have any suggestions? I have a project promised on Monday and I really need to get moving on it. It's actually a wooden sign I need to cut out and paint and I wanted to use my Cricut to cut out a pattern/stencil. This would just make life so much easier.
Thanks for any help or suggestions. Everyone here is so great. I've learned so much from reading through all the forums. I can't wait to start posting some SVG files, once I get this figured out!
Heather
AnointedHands
Re: Lines Breaking Apart?
Post by AnointedHands »
The cuts should be fine in SCAL. When I first saw that, I tried cutting anyway and they work fine. If you check your shape in the preview mode, the lines should be complete.
INK has those lines only when you view in outline mode. That is a quirk of INK. It has never had any effect on the shape.
heathrjoy
Post by heathrjoy »
Thank you soooo much Anointed. (Love your name...especially for a scraper!) I did the preview...what a novel idea, LOL! Everything looked great, full cut lines. I'll try cutting it later today. If there are any problems you can bet I'll be right back here letting you all know. :lol: Otherwise, on with the show...and hopefully to be posting some SVGs soon!
Thanks bunches!
heathrjoy
Post by heathrjoy »
I started cutting and it's perfect! :D It's so great when things work how they are supposed to. Such a relief. Thanks for helping me out. I was afraid to cut it, I figured it was going to give me a huge problem (why is it that we are used to that being the norm?) Oh, this is going to be so quick and easy now.
BTW, I got a really cute pair of baby shoes done up in an SVG today as a thank you to everyone on here who is so helpful and thoughtful to post and share all their files and helps. Now, I just have to try posting files...think I'll try attaching a pic of it here. If it doesn't work no one will care on this thread, lol!!
But, everyone can be looking for this SVG in the next day or so.
Oh, I'm so happy right now I could just dance!!!
wreed06
Post by wreed06 »
heathrjoy, sometimes I use printer paper if I just want to test a cut before using good paper. I use a slower speed when cutting thinner paper as it tends to tear. Intricate cuts don't work very well with that paper though.
