Could someone guide me on how to arch text or make text into a circle. thanks so much.
Julie
how to arch text
Re: how to arch text
How would you use this? Don't you cut it all out and you have to put it together on your paper anyways? Or am I missing something here? Unless you weld, it will be individual letters that you end up putting around on the paper. Right?
Scrappindeb
You can either use a transfer method (like mesh drywall tape), weld the letters together, or make a mat for them. HTH
Have a look here for the mentioned drywall method for transferring elements. I use this method alot.scrappindeb wrote:How would you use this? Don't you cut it all out and you have to put it together on your paper anyways? Or am I missing something here? Unless you weld, it will be individual letters that you end up putting around on the paper. Right?
http://cleversomeday.wordpress.com/2009 ... cardstock/
Cheers
Craig
Craig
