This is actually a .scut file so you would use File>Open Project.
The snowflake is the file and I have put shapes from SCAL around it. If you want to change the shape, just delete the shape that is around the snowflake and put in a new one. The snowflake should be surrounded by an object or it will not cut from the paper.
If you want snowflakes that do not separate from the paper, just remove the shapes around the snowflake and position them wherever you want. To make a 5X7 card with snowflakes only, delete the shapes from around the snowflakes (delete any you don't need or Copy/Paste if you want more), create a 10X7 rectangle and arrange the snowflakes in half the card.
Any questions, PM is the best way to get answer quickly.
Snowflake Open Cuts
Snowflake Open Cuts
- Snowflake Open Cut 0709.scut
- (162.33 KiB) Downloaded 644 times
- Picture2.png (27.14 KiB) Viewed 4330 times
