Ok, I'm working on my son's basketball scrapbook album. I've designed the following basketballs but for some reason they aren't exactly what I want. Any suggestions from the pros?
Lisa
P.S. Here are the pictures.
I'm trying to make a basketball
Re: I'm trying to make a basketball
OOPs pictures didn't work, let me try againRobbysmommyga wrote:Ok, I'm working on my son's basketball scrapbook album. I've designed the following basketballs but for some reason they aren't exactly what I want. Any suggestions from the pros?
Lisa
I like both of them.
what exactly don't you like about them?
jancy wrote:I like both of them.
They don't cut right. The basketball lines are so small. I'm just so frustrated. Another person created a baseball one in CDS and it comes out great. This one is too choppy and I don't know what to do to fix them.
Lisa
Robbysmommyga wrote:jancy wrote:I like both of them.
Lisa
when I looked at the one with the word 'basketball' on the ball, not all the letters were connected. the other one had a square surrounding it.
I could tweak them for you & repost them if you like.
Tracing images alone is not usually the be all end all in inkscape. it sometimes takes work in moving lines & deleting nodes, etc. I'd like to make a video tutorial on that, but won't have time for that for another month. That would be much easier than a picture/text tutorial.
give me a few minutes & I'll post the files with some changes for you & you can tell me what you like & don't like, etc.
jancy wrote:Robbysmommyga wrote:jancy wrote:I like both of them.
Lisa
THANK YOU so very much..
how is this for the basketball?
I made the outside "mat" one full circle--I just closed it up.
I also eliminated the double line for the area inbtween the "sections" of the ball.
if this is not what you're after, just let me know & I can change it some more.
- basketball.svg
- (6.4 KiB) Downloaded 330 times
- basketball.jpg (35.16 KiB) Viewed 5435 times
I have no idea how you did that, but omg, thank you the cut worked fabulous.
I have to leave for work right now, but I will post a picture later of the cut.
Lisa
Lisa
I did this one file attached
- bbsvg.svg
- (54.33 KiB) Downloaded 265 times
Beanie ~~Been There Done That~~
that is awesome - is that layers?
