I am uploading the windowpane card that I am trying to make. I can weld the rectangle with the window pane to make it into a card. Can you tell me what I am doing wrong?
Thank you so much.
Sally
CAN SOMEONE HELP
CAN SOMEONE HELP
- WINDOWCARD 1.svg
- (5.2 KiB) Downloaded 103 times
Re: CAN SOMEONE HELP
Here you go.. What I did was got object to path.. on the window side and then hit break apart.. I unioned your two rectangles first.. Took all you window pieces and hit object/combine the selected them and the reactangle and hit path difference. .
Thank you so much. I really appreciate this. I printed off your instructions and will do this next time.
Sally
Sally
You are welcome...
