Pumkin Top box
tuckpage
Pumkin Top box
Post by tuckpage »
Here is a box I made with different pumkins on top of each side. There are the green stems to put on top and
different sides to glue on (they can be all the same or each side different) if you leave them to the side
they can be cut out and glued on or you can put them on the side of the box before you cut to create a
cut out on each side for a candle to glow though.
pumkinPC.svg
(51.95 KiB) Downloaded 251 times
pumpkin box.jpg (16.2 KiB) Viewed 3187 times
trainwife
Re: Pumkin Top box
Post by trainwife »
Thanks for the great design! :o
Phil from Southeastern Michigan
reaton
Re: Pumkin Top box
Post by reaton »
Thanks for sharing. Really Cute.
Rosie0530
Re: Pumkin Top box
Post by Rosie0530 »
This is neat. Could you show us a picture of it cut out and put together. I just want to be sure I am seeing it the right way. Thanks. Rosie
Re: Pumkin Top box
I do believe all the dots are the fold lines.. fold into a box with an open bottom.. The pieces about the pumpkins would be glued to the top of each pumpkins and the rest of the pieces are embellishments..
tuckpage
Re: Pumkin Top box
Post by tuckpage »
yes the dots are fold lines, glue the tab at the end to the side to make the box. The green stems go on top and use the other pieces cut out in what ever color you want to put on the sides or before you cut you can place them on the sides of the box in scal and it will cut that image into the box. If I get a chance latter today I will make one of each up
sorry if this is confusing.
susiecm3
Re: Pumkin Top box
Post by susiecm3 »
Wow these are fab, i just got some little xmas candle lights this morning and will fit in fab, thank you, great craft for next weeks school holidays :)
HP laptop running vista, scal 2.011 , service pack 2, 3gb ram and a cricut expression
