cutting text inside a shape
I am trying to cut text I have put inside a rectangle and would like to have the text attached to the rectangle so it is attached to the sheet. I have tried welding but doesn't seem to work.
Re: cutting text inside a shape
Use path/difference if you are using inkscape..
Thanks for your response. I did forget to mention I am using SCAL.
I am new to SCAL and trying to do the same thing. Anyone know how to do it?
You are running into the "aperture problem." You need to create a frame first by putting one rectangle on top of another, selecting them both and then doing path>exclude. Now you can weld your word inside of that and it will work. If you are doing a card you may want to make the outer rectangle the card size and the inner rectangle the window size to start with.
Here a link to the recent video tutorials put out by craft edge for SCAL, They are very well done and explain how to do things in very simple terms. I have found them very helpful. The path menu video I will probably watch a few more times.
http://www.craftedge.com/tutorials
Syl
Syl
Firstcut also has videos on her blog.. She's a great teacher here as well
