Motocycle file not working ... brain neither
sharloww
Post by sharloww »
I cant figure out what I am doing wrong.
http://nancyscreativepapercrafts.blogsp ... motorcycle
Using this file of the motorcycle. I can't get it to cut out anything but the little pieces. I can't get the outline of the bike to cut... I also have the tire spokes messed up>...
What am I doing wrong... obvioulsy I am new...
Thanks for the help
lkc
Re: Motocycle file not working ... brain neither
Post by lkc »
The first bike shows the original file and the second one is the corrected one...I'm working with scal1 so scal2 users may be able to ungroup it in that program but I took the file into Inkscape and ungrouped it and saved it again and it showed up fine...hope that helps.
Laura
sharloww
Post by sharloww »
Laura thanks for your help...
I am still confused. How do I do what you did?
I need the second picture but my computer will not let me download it from here?
I am so sorry to be a bother
rgallegos
Post by rgallegos »
Hello,
I am Nancy, whose blog you downloaded the file from. I just happen to be browsing and came across your post. I'm glad I did!
All my files are .svg format, to allow you the freedom to edit, enlarge, and modify to meet your needs. Most are multiple pieces, and are often grouped so that when they are enlarged, it does so proportionately. You will need a program such as Inkscape, which is free, to allow you to ungroup, separate and re-save. If you will do this, then import it to SCAL, it will appear correctly. I hope this helps.
You can email me at nancyscreative@sbcglobal.net, if you need further assistance, I call email you the file in a way to make it easier on you.
Regards,
