Seems my post has gone...but...welding
Jayne
Post by Jayne »
Is it possible to weld text on a curve....other that doing it letter by letter...
firstcut
Re: Seems my post has gone...but...welding
Post by firstcut »
Jayne,
I have a video on putting text on a curve, here.
http://cleversomeday.wordpress.com/2010 ... t-on-path/
Not sure if you want to weld to a curve or just weld the letters together in a curve. You can do it either way, just use the text on path procedure first.
Jayne
Post by Jayne »
Ok ive done that...so now how do i weld the letters together...
pennsylvaniakate
Post by pennsylvaniakate »
Before (or after) you have moved your letters together, click on the letters individually and select the weld box under properties. When you go to preview, the welded parts will show up in gray after you have moved them together.
