Here's how to set up a library of your favorite cutting files in the SCAL2 shapes library.
Step #1
Download the Libitup file here:
The bottom file in the attached picture is for Widows.
Step #2
Click "Add file" for each svg you want to enter into your personal library. See picture attached.
Step #3
Then click "Export file" which creates a lcut2 file and note where you saved the file.
Step #4
Then open SCAL2 and click File, Add SCAL library, then click the lcut2 file you saved in step 3.
Your new file will appear when you click on Window, Shapes Library, then the drop down box next to shapes/basic shapes.
How to create your own library with LibItUp2
- Lib it up.JPG (25.5 KiB) Viewed 2150 times
- Lib it up CE Download.JPG (22.37 KiB) Viewed 2150 times
Re: How to create your own library with LibItUp2
Thank You Deloris. It worked just fine. Thanks for the tips.
