Rocking horse
Rocking horse
Here is a cute rocking horse if anybody needs it.
- rocking horse.scut
- (6.79 KiB) Downloaded 423 times
Re: Rocking horse
Is the rocking horse a dingbat? If you don't convert the dingbat in Inkscape, we won't be able to use it unless we have the dingbat installed on our computer.
All I get is an n which is probably the letter you typed to get the rocking horse.
Re: Rocking horse
Oops... my bad.
I guess I didn't realize that would do that. Thanks for the info! Still learning ALOT here
Christine
Christine
Re: Rocking horse
You can convert it to an .sgv file and everyone can use it whether they have the font installed or not. After you convert it, import the .svg file into SCAL and save. We should be able to see it then.
Open Inkscape
To change the font, click on the T on the Main Menu, choose the dingbat set, click on Set as default, Apply, Close
On the main screen, click on the A (near the bottom of the icons on the left), click your letter. Select with the top icon, Path>Object to Path; Path>Union.
Open Inkscape
