Here is the file for the wall hanging I posted today under DESIGNS. I cut out two files of the base and glued them together for strength. The cream layer was cut out of embossed card stock. I used the same colors for the base and top layer holdling the alphabet. Before removing the alphabet from the mat, I stamped it and embossed with chocolate embossing powder. I also stamped a swirly bird design to hang from the bottom of the hanging. Instead of chain, you could use ribbon. Instead of the stamped bird, you could hang a charm. I inked the cream flowers with brown ink to add some depth. I also went around every thing with brown ink using my home made ink dauber so it would have a vintage look.
Hmmmm, it says my file is too big. How do I make a scut file smaller?
Live,laugh, love wall hanging
Re: Live,laugh, love wall hanging
Here is an svg of the file instead of a scut2 file. You can readjust the files to make them layered and make your own letters. Sorry!
- Live laugh love template.svg
- (11.03 KiB) Downloaded 328 times
- Live laugh love base.svg
- (10.59 KiB) Downloaded 264 times
I figured out how to zip up the file. You can use a free unzip program called PeaZip if you don't have anything to open it with. Thanks Todd for the suggestion!
- Layer alphabet.zip
- (77.55 KiB) Downloaded 243 times
- Layer 1b.zip
- (87.4 KiB) Downloaded 194 times
- Layer 1a.zip
- (86.05 KiB) Downloaded 167 times
Here is part 2
- Layer2b.zip
- (80.35 KiB) Downloaded 207 times
- Layer2a.zip
- (79.57 KiB) Downloaded 168 times
