Hi. I'm new here....loving it so far!! I would like to know how to separate out colors on a picture to cut out the different layers in vinyl. I'm trying to cut out the mascot for my child's school. Any advise would be welcome.
Thanks!!!
Kim
Need help
Need help
- school mascot
- pvehawk1.jpg (44.08 KiB) Viewed 3804 times
Re: Need help
Hopefully this website will help you http://dan99.blogspot.com/search/label/tutorial.
Good luck,
Carolien
Good luck,
Carolien
Re: Need help
PS You have to scroll down to the 20th January 2009.
Cheers,
Carolien
Cheers,
Carolien
Re: Need help
I really wouldn't recommend using that method for this image since it will give you stacked traces with a thin black frame on the top of four other colors. You might try modifying this tutorial to trace each color http://dan99.blogspot.com/2009/01/video ... o-svg.html and then use a basic trace to get the black background.
I played with this image last night and wasn't happy with any of the things that I tried in Inkscape. The image is pretty low resolution with a lot of jpeg artifacts. It would be much better if you had a higher res image.
Re: Need help
Thanks for the info, I had no idea where to even start. Very appreciated.
I'll try to get a better picture from school too.
Kim
Kim
Re: Need help
Ok, I've tried...even got a better pict., but I can't figure out how to do it. I used inkscape and it will break down the hawk into a bunch of different colored hawks, but not into the individual shapes for the colors. Is what I'm wanting even possible? I don't know...
I'll attach the better hawk if there is anyone who could assist me....many thanks!!! This is for a project for my school's silent auction in a few weeks.
Kim
Kim
- color hawk.jpg (41.97 KiB) Viewed 3682 times
Re: Need help
Here ya go. i used the paint bucket with default settings to do the conversion.
- colorhawk.svg
- (63.48 KiB) Downloaded 172 times
Re: Need help
OMG!!! Thanks you, thank you, thank you!!!!!
How did you do that?
Re: Need help
Here's the finished product...again thanks for the help.
- pveblock.jpg (48.73 KiB) Viewed 3549 times
Re: Need help
Boy if I made the brown - blue instead - and changed lettering I could use that for our school back home.... if sharing file
Fighting - BlueJays - SHS - Shepherd High School - Michigan
