school bus windows
Smelly
school bus windows
Post by Smelly »
What is wrong with the windows? When I save the file as a .svg and then import it into SCAL the windows to the school bus are missing?
school bus.svg
(7.9 KiB) Downloaded 272 times
school bus1.png (14.5 KiB) Viewed 2757 times
Kelly
talanhart
Re: school bus windows
Post by talanhart »
I tried to import this into SCAL 1 and received an error message and the file is blank. I can open the file in Illustrator and everything looks good.
Open the file in Inkscape, select the windows, then use Path/Union. With Ink47 ungroup if necessary then Path/Union is the general fix.
Smelly
Post by Smelly »
i was using SCAL2
Kelly
Here you go.. It was as Heather stated.. Do a path/union.. I have SCAL2 and it looks perfects :D
Smelly
Post by Smelly »
great Thanks!
Kelly
wvcathy
Post by wvcathy »
Help Please ! - I need to make a school bus - birthday invitation - granddaughters # 2 --- theme "The wheels on the Bus " - when I do a preview it looks like the front wheel is not welded - I am fairly new to all this "Designing" thing and not familar with changing/correcting anything on .svg files.
Any help would sure be appreciated.
Regards,
wvcathy
