Shellie's SVG files-updated new files, some mesh files.
kaesmom
Re: Shellie's SVG files
Post by kaesmom »
jancy wrote:
kaesmom wrote:I hate to be a pest, but the star one is doing the same thing - cutting a big background square with just a few lines with no stars. :(
I took a look at that file. I've not tried to cut it myself, but I did open it in inkscape.
It appears to be one file on top of another & the two are "grouped" together. It might work if the file is "ungrouped"--object:ungroup & then remove either the top or bottom layer; then drag your mouse around & select the entire thing, then path: combine. then save & import & cut in scal.
i don't have scal, so I don't know if that will work, but I think it might.
It's always a good idea to check any files that you did not make. Open them in inkscape & look at the nodes & lines etc. while viewing in "ouline" mode.
hope this helps.
Well then. Guess I better download Inkscape. :lol:
jancy
Post by jancy »
hope this helps.
LOL. I was actually going to do that for you--but it's homework & dinner time, then family time & bed time routine........and ds has been pretty sick........and, and, and...........lol.
I might get a chance after ds is in bed to work on it.
kaesmom
Post by kaesmom »
Awww you're so sweet! Sorry ds has been sick. Tend to him - it's more important!
Maybe this is the incentive I need to TRY inkscape!!
jancy
Post by jancy »
here's the file after I made changes to it.
what I did:
*opened in inkscape
*changed view mode to outline
*object: ungroup
*path: break apart
*separated the layers
*path: combine --only for the "red" layer as the other one seemed fine
*path: simplify--I did this to both layers
*selected blue for the "blue" layer & red for the "red" layer
*changed view mode to normal
*saved file
Now, I have no idea if this will eliminate the problem of it only cutting as a solid square in SCAL or not, but I think it might. I know that when working with inkscape & roboaster & then to wishblade software, that if a file is "grouped" rather than combined or union under path, that the file will get all wonky & not work.
If you happen to try to cut this, I'd love to know how it worked out for you.
(shellie, I hope you don't mind that I did this. I have no problem with removing this file if you have any objections whatsoever!)
star mesh svg.svg
(60.61 KiB) Downloaded 803 times
star mesh jpeg.jpg (92.59 KiB) Viewed 7348 times
kaesmom
Post by kaesmom »
Thanks Jancy!!! That's so great!
I tried to save the file but it's not letting me. It just opens the image as a jpg for some reason. :(
jancy
Post by jancy »
kaesmom wrote:Thanks Jancy!!! That's so great!
did you dowload the top attachment that is an svg file???
I see it & download it just fine.
anyone else????
NELS
Post by NELS »
I downloaded and cut it and it worked fine. I cut one side in blue and the other in red...
kaesmom
Post by kaesmom »
I got it to download this morning as an svg file (for some reason yesterday "save file as" wasn't an option when I right clicked :| ) but I haven't played with inkscape yet (or even downloaded it!) so I haven't been able to convert it. That will be today's task!
jancy
Post by jancy »
kaesmom wrote:I got it to download this morning as an svg file (for some reason yesterday "save file as" wasn't an option when I right clicked :| ) but I haven't played with inkscape yet (or even downloaded it!) so I haven't been able to convert it. That will be today's task!
you don't need to convert it---you can import an svg into SCAL to cut it :)
kaesmom
Post by kaesmom »
Ha! I forgot about that! I've been focusing so much on learning Inkscape that i forgot SCAL had an import feature. :D
