here's the file after I made changes to it.
what I did:
*opened in inkscape
*changed view mode to outline
*object: ungroup
*path: break apart
*separated the layers
*path: combine --only for the "red" layer as the other one seemed fine
*path: simplify--I did this to both layers
*selected blue for the "blue" layer & red for the "red" layer
*changed view mode to normal
*saved file
Now, I have no idea if this will eliminate the problem of it only cutting as a solid square in SCAL or not, but I think it might. I know that when working with inkscape & roboaster & then to wishblade software, that if a file is "grouped" rather than combined or union under path, that the file will get all wonky & not work.
If you happen to try to cut this, I'd love to know how it worked out for you.
(shellie, I hope you don't mind that I did this. I have no problem with removing this file if you have any objections whatsoever!)
- star mesh jpeg.jpg (92.59 KiB) Viewed 7366 times
