Hi - Finally had a chance to cut this and it worked. You are right there are some double images in the O which means it will cut 2 times. I deleted the extra images. There is also an area near cupid's hair that I could not get the points to join but this did not impact the cut. I got it to cut from the original file.
I deleted the extra areas in the O so it will not cut 2 times and here is the updated SVG (I added today's date to the end of the file name).
I sure hope this works for you!
Amy
here is my cut:
Help!!
Re: Help!!
- AimitupCupidChallenge021310.svg
- (23.99 KiB) Downloaded 188 times
- Ocut.jpg (121.51 KiB) Viewed 1485 times
Re: Help!!
Thanks everyone for your help. The "O" did cut.
