Help!!
Aimitup2
Re: Help!!
Post by Aimitup2 »
Hi - Finally had a chance to cut this and it worked. You are right there are some double images in the O which means it will cut 2 times. I deleted the extra images. There is also an area near cupid's hair that I could not get the points to join but this did not impact the cut. I got it to cut from the original file.
I deleted the extra areas in the O so it will not cut 2 times and here is the updated SVG (I added today's date to the end of the file name).
I sure hope this works for you!
Amy
here is my cut:
AimitupCupidChallenge021310.svg
(23.99 KiB) Downloaded 188 times
scrappinginTO
Re: Help!!
Post by scrappinginTO »
Thanks everyone for your help. The "O" did cut.
Aimitup2
Re: Help!!
Post by Aimitup2 »
I'm glad it worked out!
