is there an svg viewer that lets you see the files in the folder you keep them in?
Ann W
svg viewer
Re: svg viewer
I use the snipping tool in Windows to create a picture of my cutting file.
I open scal and import the svg then snip a picture of it and keep it in a folder with the cutting file.
I use the same names for the picture and svg file so that they are easy to find.
I store the folders by type such as flowers, borders, animals, holidays....
- Capture.JPG (13.35 KiB) Viewed 4316 times
Re: svg viewer
Deloris, you said you used the snippet tool in Windows. (I assume Vista) How did you do this without getting the grid lines from SCAL?
Re: svg viewer
I used Inkscape to open the svg file so that's why it's not showing the grid.Awesome Cartoons wrote:Deloris, you said you used the snippet tool in Windows. (I assume Vista) How did you do this without getting the grid lines from SCAL?
Re: svg viewer
i need a program that will show them in the folder i have them in,if i could find the renesis program i had thats what it did.
Ann W
Ann W
- Location: DFW area of Texas (how do I set my 'language' to Texas English?)
Re: svg viewer
Ann,
Not sure this is what your looking for... but here is a program by the same name...
http://www.mediafire.com/?1y0wt3gnjax
Hope this helps..
zippes
Hope this helps..
zippes
Remember… nothing is completely worthless…
It can always be used as a Bad Example!
Re: svg viewer
Thank you so much , that was it.
Ann W
Ann W
Re: svg viewer
I downloaded that but now all i get is the IE symbol on my files instead ....
When you click thumbnails it would be great to see the design instead of having to click ever single one to preview....
Re: svg viewer
For anyone having Coral PSP 9 and newer it has the ability to be a svg viewer. All you have to do is set it to read them.
File then preferences then file format associations and then find the svg box and check it.
When you use the browse function and find your file it will show your svg's
Re: svg viewer
ive just done that with my psp and it doesnt work, so closed it down and opened psp again, and it doesnt show svg,s it just very quickly shows boxes then they disspear real quick...so check file assoc and svg is still ticked
