I need a house shape!
Dubai-Lass
Post by Dubai-Lass »
Hi all
I have had a quick nose around the forum, but not quite sure where ot look!
I need a house shape, that has a seperate roof and the house shape has just one door and one window cut out (does that make sense?)
Any idea where I get it from? Thank you for your help :)
xx
pennsylvaniakate
Re: I need a house shape!
Post by pennsylvaniakate »
This is one dimensional, right? Something flat to go on a card?
pennsylvaniakate
House with one door and window, separate roof, and includes chimney and door handle. I did make the door attached, and it does cut a double line. I didn't have any problem when I cut it, but I can alter it if you would like. I did think we were suppose to be able to cut single lines with the latest version of SCAL.
Ha, it won't let me attach the file. PM me your email, and I can send you the file if you need it right away.
pennsylvaniakate wrote:I did make the door attached, and it does cut a double line. I didn't have any problem when I cut it, but I can alter it if you would like. I did think we were suppose to be able to cut single lines with the latest version of SCAL.
We have found that if the files with single lines or curves go over or even just touch the cutting boundary that they won't always cut correctly. I use the alignment buttons, then nudge the files away from the boundary with one nudge.
pennsylvaniakate
Yes, I remember reading that. I always have my files away from the line, so I knew that wasn't the problem. I still have the last version of Inkscape and wasn't sure if that was what was wrong, or if it is just my design. As soon as we can add attachments again, I'll upload the file.
Dubai-Lass
Sorry ladies for not getting back to you. Yep, one dimentional is what I want and I need to give the card in by Sunday.
xx
Is this what you need???
Carolien
Post by Carolien »
Maybe this site can help you http://donnamundinger-popsicletoes.blog ... right.html. The sun, the cityfont and the grassborder can be found somewhere on this craft edge blog. So please respect the copyrights.
Good luck,
Carolien
House 2 with foto frame.JPG (29.94 KiB) Viewed 3594 times
pennsylvaniakate
Here's the one I made after you asked, and we were having uploading issues.
house.svg
(5.59 KiB) Downloaded 155 times
