MS BUTTERFLY PUNCH...please someone?????
junqueandroses
Post by junqueandroses »
I am in love with this punch and I don't have the $$$$to buy it....but, my cricut and scal can cut it......so who is going to be our hero and make this an svg for us?? Every other butterfly is only partially cut out so it looks 3-D....thanks in advance
Re: MS BUTTERFLY PUNCH...please someone?????
It looks like they just took the cut out butterflies and glued them on the dots.. Are those the ones you are speaking of???
junqueandroses
No....the punch actually cuts one completely out and then the other only partially so that you can pinch the wings and make them like 3d...am I making myself clear...sometimes I see things differrently than I talk....lol :roll: :roll: :roll:
What do you think?????Can it actually be designed and cut that way?
You are so good at this.....if anyone can do this ....you can!!!!
Okay this is one that I've done thus far.. I can try another as well where some of the butterflies are still attached to the insides of the shapes..
Deloris
Post by Deloris »
I traced it with Inkscape 0.47 and saved as SCUT file.
Haven't tried to cut it out yet so I'm not sure if it will work with the pop up wings.
MS Butterfly.scut
(22.16 KiB) Downloaded 707 times
Butterflie Border.JPG (32.96 KiB) Viewed 6142 times
Here is a second with every second butterfly joined..
junqueandroses
OMG....you are simply wonderful......off to see how it cuts.......will post my results.
junqueandroses
Deloris....your border cut great...however.....you must use a sharp blade :lol: :lol: :lol:
I'm still working on the others. Thanks
Deloris
Post by Deloris »
junqueandroses wrote:Deloris....your border cut great...however.....you must use a sharp blade :lol: :lol: :lol:
Thanks, I'm glad it worked for you. I thought the tiny cut out area where the butterflies pop up might cause a cutting problem if your blade wasn't real sharp and your mat very sticky to hold the paper down.
I had to literally split the butterflies in half in my files.. Poor little critters..LOL.. I hope it works for you .. And great job as well Deloris :D
