and here is the bulldog.
this file is color grouped.
the base is white, then the gray layer, then the black outline, and finish with the blue collar.
Also,
You could cut the black outline as a window decal.
Hope this works for you.
Taking Requests - Any SVG Shape
Re: Taking Requests - Any SVG Shape
- bulldog.png (41.16 KiB) Viewed 7733 times
- bulldog.svg
- (58.11 KiB) Downloaded 584 times
Hi...would it be possible to make an svg for this cupcake wrapper?
Thank you so much for your generosity in sharing your talent and time...it is very much appreciated!
- cupcake wrapper Filigree_CWR_White.jpg (209.75 KiB) Viewed 7702 times
I think you got most part right with two exceptions.jcleith wrote:ok i cut the file and it cut some things i dunno if im doing it wrong or it just doesnt look right what you think?
The cut you had on white paper should be the brown cut. And the cut that is on the brown paper should be on white.
Secondally, you may need to adjust the size of the green jacket to fit the size. I eyeballed it when I placed it on the SCAL. So you may have to adjust the size of the jacket to nicely fit. It seems like that the boy is wearing XL size while a Medium size jacket should do
Bani.
From the image you provided, this is the closest we can get. Your best bet will be to start from a pattern image instead of the picture of end project. But give this a shot.nanacho wrote:Hi...would it be possible to make an svg for this cupcake wrapper?
Bani
- CupCake-PATTERN.svg
- (73.37 KiB) Downloaded 685 times
wow...thank you so much, Bani!!!
I think the best thing to do in this instance would be to buy the wrapper, and then make your own by opening up the cupcake wrapper so it lies flat and scan it and then create your own....
I am in DESPERATE need of this image as an CUTTABLE COLOR BROKE APART SVG CAN YOU HELP??
i ONLY NEED THE INDIAN AND THE WORDS, NOT THE DARKER PART
- mascountin.jpg (5.1 KiB) Viewed 7677 times
thank thanks thanks. you are great.
nateandsara the image is too small.. we would need a bigger and clearer image to convert it over to an svg..
Hopefully you are still requests. I was wondering if you could anything with this file. I have tried to put it together in SCAl with no luck.Thank you for your help.
I am hoping that someone can help me, please
- softball_girl.scut
- (26.04 KiB) Downloaded 565 times
