I created an this SVG in inkscape, however when I import it into SCAL2 it the size and postion are:
X: 10416.66 Y:10416.66 Inch
W: -10416.66 H: -10416.66 Inch
Any ideas as to why this is happening. I drew it with the free hand pencil. I have tried applying different paths.......but I am still at a loss.
Inkscape SVG to SCAL?
- Briar Scroll.svg
- (29.79 KiB) Downloaded 335 times
In His Grip Forever!
Re: Inkscape SVG to SCAL?
I'm not sure what exactly is happening with your original file, but all I did was copy your path in the original file and paste it into a new inkscape file and it worked in SCAL2. HTH
- Briar Scroll 2.svg
- (20.28 KiB) Downloaded 316 times
Thanks so much!
Not sure why it decided to be a pain. Now I can continue to working on my Splash Mountain page from 2005
I am a few years behind.
Happening Again?! Inkscape SVG to SCAL?
GrippedbyGod wrote:I created an this SVG in inkscape, however when I import it into SCAL2 it the size and postion are:
Any ideas as to why this is happening. I have tried applying different paths.......but I am still at a loss.
This is happening to me again with a different svg I have been working on in inkscape................
Any solutions?
- Coffee-Tea Mug.svg
- (17.61 KiB) Downloaded 252 times
I would guess that you are using Inkscape 0.47. Something just gets messed up with the file code, especially if you use the Path Effects Editor. Try selecting your artwork, then copy and paste into a new document. HTH
Ungroup everything until no more Groups are listed, Control A to confirm no more Groups. Do Path/Union on everything. That worked on my system.
BTW, you have a lot of nodes, and might want to simplify (Control L). If it is too severe, go to File/Inkscape Preferences/Misc and decrease the Simplification threshold until you are happy with the results. The more nodes, the lower you will want this number...I usually use between 1 and 4. HTH
