Separating an image
Col
Separating an image
Post by Col »
How do I separate the sections of this image so that I can cut them in different colors? I've imported it into Inkscape but now I don't know what to do next.
chuck e cheese.svg
(2.31 KiB) Downloaded 271 times
talanhart
Re: Separating an image
Post by talanhart »
When I open the file, all I get is a box.
Col
Post by Col »
Can you open this one? I don't know what I am doing wrong.
Chuckecheese.svg
(2.32 KiB) Downloaded 256 times
GrammyKrausse
Post by GrammyKrausse »
nothing there. But big red X Could you see if you can open it in Inkscape
Grammy
Col
Post by Col »
That is so weird. When I click on it the image appears. Ok here is a link to the image.
http://pittsburghmom.com/cfs-filesystem ... heese4.gif
GrammyKrausse
When I go to the site you are referring to it is a gif not a scut or svg. It needs to be converted before breaking apart. There are wonderful tuits on this site.
That image is a little low res (only 29 kb), you can use it, but you should probably take it into a photo editing program and make the lines around the mouth sharper (darker). The best trace I could get as-is was with a Brightness threshold of 0.29 and some of the lines were still broken.
You might try the paint bucket tool. See Firstcut's blog for more on that. http://cleversomeday.wordpress.com/2009 ... -inkscape/
toolees
Post by toolees »
See if this works for you. I separated each color into a separate cut, and have sized it to make approximately 6 inch wide project when finished. See the instructions in the Readme file included.
http://www.filefront.com/14723693/ChuckECheese.zip
Col
Post by Col »
Toolees
Thanks. Here is a copy of Chuck in his glory. Sorry for the colors I took it with an iphone.
I ended up putting all of the layers onto one project so I could reduce the size of the image. Is there an easier way to reduce all of the images
so that the reduction is symetrical for all of the pieces? It took forever to do it the way I did.
toolees
Post by toolees »
Essentially the way I made the SCUT files is to open the SCAL software and layer each of the SVG's on top of each other, sizing them appropriately so they come out right in the end. Once you have everything sized properly, move each cut so that they are no longer on top of each other, then delete all but one cut and save the SCUT file. Then perform an "undo" until you get all the cuts back on screen again, and proceed accordingly. Soon you should have each cut sized appropriately, and saved in it's own SCUT file. It is time consuming, but I really don't know any other way.
