How do you mirror a shape in SCAL 2?
JodyP
Post by JodyP »
I have the haunted house that I need to mirror so I can weld them together to make a shaped card. I can only see how to filp up/down, both buttons do the same thing. I need left to right. Does that make sense? Help would be greatly appreciated. I search the forum but not luck, just flipping words and this works but not shapes.
Thanks.
haunted house.jpg (44.62 KiB) Viewed 1250 times
HeatherM
Re: How do you mirror a shape in SCAL 2?
Post by HeatherM »
That is a bug with version 2.004 and svg files. If you de-select the "Keep proportions" box in the "Position_Size" window, the flip buttons will work with svg files. You can check the "Keep proportions" again after the flip. HTH
JodyP
Post by JodyP »
Thanks HeatherM, I would not have figured that out in a thousand or so years. thanks again.
