Help with Design in Inkscape
Tips, Tricks and Tutorials for using Inkscape
watson90
Post by watson90 »
All,
I created this design in Illustrator and have tried everything to blend the entire thing together. However, for some reason, when I import into SCAL 2 it is still showing the other figures to cut below the top block. I can't figure this out to save my life.
Thanks for your help and input.
Nancy
Fleur De Lis Pendant.svg
(191.63 KiB) Downloaded 219 times
Craigg64
Re: Help with Design in Inkscape
Post by Craigg64 »
When you view your svg in inkscape in outline mode (View - Display Mode - Outline) you will see all the cut lines.
To solve this you will need to weld the objects so that they become one.
I would start by making sure that your Fluer De Lis is one object (weld together). At the moment yours is a lot of indidual objects.
Once placed all your fluer de lis weld them together.
Hope that helps. :)
cheers
Craig
I have had ago cleaning up your file and here is my attempt. Couldn't do too much with the smaller one.
I ended up Union and Exclusion options if that helps.
(49.55 KiB) Downloaded 273 times
Cheers
Craig
Craigg64
Post by Craigg64 »
Here is one I have been working on
Fleur de Lis.svg
(73.01 KiB) Downloaded 261 times
Cheers
Craig
watson90
Post by watson90 »
These all look great, thank you so much for all your help!
watson90
Post by watson90 »
I just wanted to show you what I did with that SVG that you helped me with. Thank you again!
talanhart
Post by talanhart »
That looks really awesome!
lkc
Post by lkc »
Beautiful design...thanks for sharing your finished product, too! Looks great!
Laura
