Taking Requests
Re: Taking Requests
I am desperatley look for a loon cutout. Can you help?
Re: Taking Requests
einneJ has one on her site.
Karen
Karen
Re: Taking Requests
I am taking requests for custom SVG for your SCAL project. You may also send me your JPEG or any sample image file to convert to cricut cutable layers. Will gladly convert them over for you. You may also email me your requests at cuts2die4@gmail.com
Will be getting some of these images soon.
Bani.
Bani.
Re: Taking Requests
Tina, If you have a scanned image of the fish you are looking for, I can provide you the SVG. Let me know.Tina 1 wrote:I am in search of the fish in Dr. Seuss' One Fish, Two Fish book. Thank you.
Tina
Bani
Re: Taking Requests
Could you make an Alligator or Crocodile?
Re: Taking Requests
Certainly. Let me turn that around for you shortly.chrry6872 wrote:Could you make an Alligator or Crocodile?
Peace,
Bani
Re: Taking Requests
Jkiehna75,jkiehna75 wrote:How about a DSLR Camera like a nikon d80? That would be great. Thanks
This one is for you. I have purposely left out the "n" of Nikon from the image to not cross any copywrite issue. Check it out. I also went ahead and saved the SVG layers in a SureCutsALot library format. That way all your images will be organized. All you need to do is simply place this file in the "Library" folder of the Sure Cuts A Lot under C:\program files\..
Next time you open up your SCAL, the images will be under shapes section for you. Enjoy and let me know how this turned out.
- Nikon.lcut
- Please this file in the Library folder of your Sure Cuts A Lot and the shapes will be available to you in SCAL when you open it next time.
- (60.52 KiB) Downloaded 477 times
Re: Taking Requests
Anna,buddhacow wrote:I am desperatley look for a loon cutout. Can you help?
Attached is the Loon you have requested. Check it out. I also went ahead and saved the SVG layers in a SureCutsALot library format. That way all your images will be organized. All you need to do is simply place this file in the "Library" folder of the Sure Cuts A Lot under C:\program files\..
- Loon.lcut
- (234.48 KiB) Downloaded 379 times
Re: Taking Requests
Attached is the requeste Croc. It has two layers. Black should go as a base, and green should be the second layer. Overlaying the two on top of each other will give you a Croc like below. Enjoy! Shouldn't we put these in a gallery for downloads instead of the forum? I have fun giving you guys quality images to cut off your Cricut. Any thoughts on the downloadable gallery concept? I found it tideous to sort through the forms to get the image I want. would you agree?chrry6872 wrote:Could you make an Alligator or Crocodile?
BTW, you may notice the file I uploaded is now SVG. It is a library file that easily stores all your layers per image in a library for SCAL. Let me know if you have any trouble opening or cutting using the file. Let me know if this is easier or should I just email the SVGs. I noticed that in order to get a very good output, you must have more than 1 layer in most cases. Hence, uploading the library file instead of individual SVGs should save you some time. At least that's what I thought. Let me know if that was of some help.
Peace.
Bani.
- Croc.lcut
- (72.73 KiB) Downloaded 363 times
Re: Taking Requests
Can you do this one? I tried but can only get the darker part to show up. thanks
- sde335.gif (16.37 KiB) Viewed 5840 times
