Lotas
wreed06
Lotas
Post by wreed06 »
Lotas
Notes: Each petal is a separate piece and appears not to have any clear layers. Elegant flower.
Sunflower
Notes: Really neat sunflower scene. Detailed. Suggestion to use brown velum as the top layer of flower center. Use white or silver/gray velum for clouds. (If Cricut cuts velum nicely?). This one requires some time and patience, end result will be fabulous!
sun_flower.svg
(37.95 KiB) Downloaded 974 times
lotas_yogesh_kanitkar_01.svg
(17.07 KiB) Downloaded 1017 times
iluvshinythings
Re: Lotas
Post by iluvshinythings »
I tried to import this into SCAL and I get an error message that says that SCAL must shut down. Help!
HeatherM
Re: Lotas
Post by HeatherM »
The lotus flower needs to be ungrouped in Inkscape. The stem also needs to be selected, then Path/Stroke to path. It should work OK after you do that. HTH
coocoo4cricut
Re: Lotas
Post by coocoo4cricut »
wreed06
Thank you for the lotus flower I love all things asian.
Thanks for your genius HeatherM is there anything you can't do :D
