Pocket Fold Invites
Pocket Fold Invites
Hello has anyone created an SVG like the pocketfolds found here? http://cardsandpockets.com/index.asp?Pa ... ategory=91
SCAL 1 Ink0.47
Re: Pocket Fold Invites
I haven't noticed anything like this - I do have one around here somewhere as my sis-in-law used these for her invites. If no one else responds, let me know and I will dig it out and create a file for you.
I too would like to have this cut file if you are sharing. Thanks in advance.
I have never seen one but they are cool. does the flap tuck in somewhere or do you "tape" it down? I am going to try to work on one from the pic ... but Lora is MORE than welcome to dig out the one from her SIL
I only have a personal so I can't cut it too big ... I hope it works!
- imagefold over card pointy.png (3.41 KiB) Viewed 6335 times
- fold over card pointy.svg
- (5.66 KiB) Downloaded 4286 times
here is a rounded one ...
- imagefold over card rounded.png (2.75 KiB) Viewed 6329 times
- fold over card rounded.svg
- (3.47 KiB) Downloaded 560 times
Those look great - you beat me to the punch by a few minutes!
I have test cut mine and it works great - I'll go ahead and add it as the pocket shaping is just a little different and perhaps a softer angle on the pointed flap.
This .scut file is already sized and ready to cut.
To cut the inner cardstock pieces - the invite is 4.75 x 6.75 and the side cards are 3.75 inches wide - tallest is 6.75 and I made the others each 1" shorter than the previous one.
Thanks much guys...I tried making it by attaching a triangle to a rectangle but I could not get the edges of the triangle lined up flush with the rectangle even though they were the same width. What did I do wrong?
SCAL 1 Ink0.47
When trying to perfectly align objects, I select the objects I want to align and use the Object>Align and Distribute option from the menu.
