Line cutting order
kenny46
Line cutting order
Post by kenny46 »
Hi all I have SCAL pro 5 and I need to change the line cutting order to get the cut corners perfect is this possible in this software? If not can you let me know if there is a software that you can stipulate the cutting order please?
Regards
Kenny
Re: Line cutting order
Please refer to Section 8.06.6 Cut Order Control in this SCAL5 user manual:
https://www.iloveknk.com/0um/SCAL5/SCAL ... Manual.pdf
If this doesn't address your question, please post a screenshot of your project and a zoomed in screenshot of the Layer Panel with your project ungrouped. Thanks!
kenny46
Post by kenny46 »
Hi I have attached what you asked for and a zip containing the actual project for SCAL 5. What I am trying to do is dictate the path the cutter will take and not what the software tells me it will do. I do hope the reason for this will be come apparent when you see it.
Regards
Kenny
H1 A-B TEST.zip
(20.49 KiB) Downloaded 169 times
I have confirmed that there IS a bug in the cut order control as per the instructions I wrote in the user manual that did work correctly at one time. I'm testing on a Skycut cutter. Will you please post the brand and model of cutter you're using in case it's not true across all cutters that work with SCAL5. Thanks.
kenny46
Post by kenny46 »
My cutter is a UKCutters HWF330 with ARMS. Many thanks for your assistance with my issue.
Okay thanks! I'll let the developer know about it but I have a feeling it's for all of the cutters. I can get the video simulation in the Cut Order Control window to cut in the order I want (Layer Panel) order but when I send it to my cutter, it cuts the default way.
kenny46
Post by kenny46 »
Thank you Sandy much appreciated
