Cut file
cowboyzfan72
Cut file
Post by cowboyzfan72 »
Can someone PLEASE help??? I have been trying to make a cut file (SVG) of a chef picture I have, and after 7 days I give up. I have Inkscape and SCAL, but I cannot do it. If someone is really good at inkscape, and they are willing, I would be so appreciative if they can try to make this into a cut file. I keep getting double lines and no matter how much I read, I cannot figure out how to get rid of them...Thanks in advance
Re: Cut file
Are you going to cut this and piece it? Because without a lot of modifying it will cut into a lot of pieces. The reason I ask is because I can see two ways to handle this.
cowboyzfan72
Re: Cut file
I am going to cut it out of vinyl and use transfer tape to attach it to a wall....Thanks for answering
Re: Cut file
So you will use just one color with minimal pieces?
cowboyzfan72
Re: Cut file
Yes
Re: Cut file
Here is what I have so far. Let me know what you think. It still needs more simplification of the nodes around the face.
Scan_2.svg
(23.61 KiB) Downloaded 399 times
cowboyzfan72
Re: Cut file
Thank you everyone for all of your help. I got a file I can use and when I am all done, I will post a pic. Thanks again!!!!!
dees-creations
Re: Cut file
Post by dees-creations »
I have been looking everywhere for this file also..is there any way I can get this..I was directed here from the cricut board...I would so appreciate your help.thanks
Dee
naniofsix
Re: Cut file
Post by naniofsix »
I also would be interested in the cut file....
cowboyzfan72
Re: Cut file
This came out great in vinyl. There are a lot of little pieces, so using transfer tape (or clear contact paper, which is what I used) helps alot...Enjoy
chef.scut
(225.27 KiB) Downloaded 474 times
