How to do a SCREEN CAPTURE to post with your file
It is always more useful when you post a file to also post a picture of the file so others can see what it is before it is downloaded. I believe that a capture of the actual SCAL file is best, but an Inkscape file is good also.
If you are so inclined a .jpg or png of the original or use of the file is much appreciated.
Here's how to do it or where to find out how to do it.
ON A PC
To take a screen shot of your file either in Inkscape or SCAL on a PC go here:
http://graphicssoft.about.com/cs/genera ... enshot.htm
ON A MAC
Taking a picture of part of your screen
If you don’t need a picture of your entire screen, you can capture just part of the screen using Grab.
To take a picture of part of your screen:
Open Grab, located in the Utilities folder in the Applications folder.
Open Grab
Choose Capture > Selection.
Move the pointer to a corner of the area you want to capture.
Drag the pointer across the area and release the mouse button.
Grab captures the part you selected within a few seconds. A new window appears with the image of the selected area.
_
firstcut
Re: How to do a SCREEN CAPTURE to post with your file
Post by firstcut »
Alternately on a Mac, just press shift-command-3 for the whole screen or shift-command-4 to select part of the screen. The resultant images show up on your desktop.
jsnstarprncss
Post by jsnstarprncss »
Thanks for the info Susan...I have a question though.
I grabbed (on my Mac) and posted it to the forum, but because the image is a .tiff it won't upload to facebook and I can't see it unless I'm in Safari (right now I'm in Firefox). Is there a way to Grab and make it .jpg?
~Ashley
Psalm 113:3 Creations
firstcut
Post by firstcut »
The Grab application saves as tiff, the keyboard shortcuts I gave save as .png
Not sure if Facebook takes png or not but all the major browsers should be able to see pngs
If you need to convert either tiff or png to something else, open the file in Preview(probaby the default app for these already) and do a save as... to jpg.
jsnstarprncss
Yes, FB does take PNG--thanks so much, Kay!!
Another ? : what's the difference between PNG and JPEG?? Is this going to affect my pictures that I take with my camera??
~Ashley
firstcut
Post by firstcut »
PNG allows transparency so it is easier to work with in some applications, and it features lossless compression. It is a format that is gaining popularity, especially with graphic artists, but I don't know of any impact it has on our digital photo taking.
jsnstarprncss
Great. Thanks for all the info! I tried out the command shortcut and it's so much simpler!
~Ashley
deliacm
Post by deliacm »
On a PC that runs Vista, the "Snipping Tool" is great and really easy to use. It's in the Accessories folder. I just add it to my Taskbar so I can access it instantly when I need it.
Christina
“I do that which I cannot do in order that I may learn how to do it.” ~Picasso
sunnyNP
Post by sunnyNP »
I never knew about the snipping tool on vista......THanks so much for sharing!!!!
btails
Post by btails »
Well Christine look what you have taught me..all this time you all have been talking sreen shots and it was already on my vista..just waht I wanted....thanks all you Ladies
