print and cut on sure cuts a lot 4 pro
cgrisales
Post by cgrisales »
I just purchased the US Cutter LaserPoint 3 with SCAL 4 Pro for MAC and I am trying to follow the Print and Cut directions but when I print the image before cutting I don't see any registration marks and I don't know what I am doing wrong and can't find a video online.
Re: print and cut on sure cuts a lot 4 pro
Several things can cause this:
(1) In the Print window, did you mark the option for Print Registration Marks?
(2) The layer that will be cut, versus the print layer, do you have that layer showing or hidden? It needs to be showing and, on the Style Panel, you can assign it as Print + Cut Cut. It won't be printed BUT it needs to be active anyhow so that the registration marks will be printed in their correct locations.
(3) In the Cut Settings window, make sure you do NOT have "Cut Selection Only" marked unless you've also selected your cut layer back in the main window so that it's highlighted. I know... kind of confusing. So, for now, just turn off that option.
If you still have issues, please post back with screenshots of each layer selected with the current settings on the Style Panel showing. We'll get it figured out.
