Object to path
realred
Object to path
Post by realred »
Trying to curve some words and the directions say Object on Path. There is only an Object TO Path on the newest version of SCAL v4. Please advise.
Re: Object to path
Will you post a screenshot? I just checked the latest SCAL4 on both of my computers (PC and Mac) and they both still show Object On Path.
Re: Object to path
Never mind... I know what function you were using. That's not the one you want. Instead, you want to select both the text and circle and go to Effects>Object on Path. Refer to Section
Re: Object to path
Note that to use this function, start with a circle and the text. Make sure the text layer is above the circle layer on the Layers Panel. Then select both and go to Effects>Object on Path. The other function you were attempting to use is for converting text to a vector object. Note that you can also curve text using the Type on Arch option in the Text menu on the Tools Panel (left side).
