Silhouette Nativity
Silhouette Nativity
I want to cut this in vinyl and make a lighted glass block
- I was able to use Inkscape to convert this image to a svg and cut in SCAL.
- CIMG0061.JPG (219.09 KiB) Viewed 5294 times
Re: Silhouette Nativity
GOOD FOR YOU! It is beautiful and well worth the time to do it. This will never go out of style or vogue!
Thanks for asking and the comments.. and thanks for the encouragement papasue. Sorry, I didn't explain this in my post. This is an image of my favorite Nativity stamp. I stamped the image. The image wasn't defined enough to work with so I took a fine marker and redid it in black. Then scanned it and saved it as a jpeg image. Then imported it into Inkscape. Changed to outline mode, did the trace bitmap, deleted the red x and then put in view Normal mode and then saved as a svg. There are tutorials on doing this. When I cut it out the halos didn't cut right so I just cut them off of Joseph and Mary. I want to remove them from the svg image I have so I need to work on that. I can't share the file because of copyright. But this does show how you can take a stamped image and convert it in Inkscape and Make a svg. Here is my stamped image.
- CIMG0063.JPG (116 KiB) Viewed 5208 times
You did a great job with this!
Good for you! That turned out so pretty.
BJN,
great job. i could never alter such. for those like me unable to alter, there is a dingbat somewhat like that. i got mine at dafonts.com - Christmas - title = SLCHRISTMAS. yes it is free.
i totally understand the copy right issue.
Theresa
