Help! When I scan an image and import it into inkskape, the image is not the actual size as the image I scanned.
Example: I scanned a stamped image that was approximately 3 inches tall and 1.5 inches wide, and when I import it into inkscape the image measures approx 5.5 inches tall and 3 inches wide.
Does anyone know how to make your image you scan import into inkscape at its ACTUAL size? Any help would be greatly appreciated, thanks!
HELP PLZ! Scanned image not ACTUAL size when I import to ink
Re: HELP PLZ! Scanned image not ACTUAL size when I import to ink
I don't do scanned images but you can make the image the size you need in the correct proportions by using the lock between W & H. Just click the lock and, for instance, you said the image is 3 inches wide once opened in INK, type in 1.5 (the correct width) in W and it should change to the correct height.
HTH
HTH
