Hello, I'm in need of some help. I've tried to make this pocket wedding invitation myself but I totally get confused with inkscape. I'm doing this for a friend for his wedding and I have tried to do one using inkscape but my lines are always uneven. Could someone please help me and see if this pocket can be made? I would truly appreciate it.
Thank you so much.
Trakia Johnson
Can someone make wedding pocket into an SVG please?
Re: Can someone make wedding pocket into an SVG please?
just looking at the inside text part, would that be 6" x 6"?
if so, the card would be in two pieces, and need to be glued together.
Is that what you are looking to do? do you need all the pieces made or just the pocket part?
Hi, I need the entire thing if possible. I've tried to attempt it in inkscape and I'm at a lost.
try this, let me know if you need it tweeked.
Right now it is designed so the finished-folded size is 6"x6"
- wedding invite.svg
- (2.87 KiB) Downloaded 682 times
Thank you so much. I haven't tried to cut it yet. About to try it now. Will let you know how it looks. Once again, thank you so much.
Thanks again
Trakia
Thanks again
Trakia
