Having hard time with this.
Linda
Re: Having hard time with this.
Post by Linda »
Ok, trying again!!
Untitled4.svg
(31.26 KiB) Downloaded 115 times
Linda
Brookville, Pa.
Linda
Post by Linda »
I'm about to pull my hair out! I removed everything but the main letters and I can't even open it. I guess I can try and start over from scratch and see if that helps. I did save the file on the cloud if anyone would be interested in trying to open it from that file in an e-mail.
Linda
Brookville, Pa.
Linda
Post by Linda »
Either I'm not doing something right or there is a problem with my scal. I imported a different svg file. I then exported it as an svg. Now it won't open either.
Linda
Brookville, Pa.
talanhart
Post by talanhart »
What version of SCAL are you using? I think 2.044 is the latest.
dragonlord666
Post by dragonlord666 »
scal 3 is up to version 3.050 now
Gaz
Computer:IMac running Mojave
Linda
Post by Linda »
I was working with the version before the 3.050. Just a little bit ago I upgraded to the newest and it didn't make any difference. I tried do simple text and exporting as svg and I get a blank page when I import the file.
Linda
Brookville, Pa.
dragonlord666
there is very little difference between 3.49 & 3.50 for most of us - I think it was 1 cutter was added and communication with ecraft cutter.
Gaz
dragonlord666
Linda wrote:I was working with the version before the 3.050. Just a little bit ago I upgraded to the newest and it didn't make any difference. I tried do simple text and exporting as svg and I get a blank page when I import the file.
humm.. OK so I"m on a mac but I just typed some text, exported as svg, file>new, then imported the file and it's fine.
might be you need to re-download and re-install
Gaz
Linda
Post by Linda »
I decided to go up to my laptop that is connected to my cutter. I had been working downstairs on my desktop. Anyway, I exported as a svg and then was able to reopen the file and see it! So, here's crossing my fingers that it works and you can open it.
parkacres.svg
(38.26 KiB) Downloaded 124 times
Linda
Brookville, Pa.
dragonlord666
OK had a quick play and using just the letters from your file I ungrouped them, select each one and did either path>back minus front or path>front minus back - if I did one and hte letter vanished then I did ctrl + Z (undo) and do the other one - this got rid of the inside bits of the letter like "P" etc then used object>add shadow a few times changing colours etc I got this, which I think is close to your bottom image. don't know if it's any good.
Screen shot 2013-04-19 at 01.30.02.png (191.56 KiB) Viewed 3338 times
parkacres2.svg
(273 KiB) Downloaded 167 times
Gaz
